jordys ski boat
- 149
- frankston melbourne
here are some photos of me fabricating my manifold to suit an eaton m90 and shortening the bellhousing for the marine gearbox. the 1uzfe manifold is easy to work with i milled the ports as close to the flange as i could to get a flat surface to weld the alum plates to and pressed out some bellmouths to weld into the plates to even out air flow i bit. the only slight problem is you have to roll the bottom plate that joines the two manifolds to miss the starter motor. so all up the manifold costed 160$ and about two days work it was a fun job to do.
