chrisman
- 377
- chicago,il,USA
hi guys--anything new and exciting?.. well,, i thought since i will be slowly getting the v8 corrola together, i might as well post pics of the "diabolical" stuff im making for it..:mischievo . it will be spread over the next month or so,, but it should be interesting enough..
for those guys who have just heard of this car,, its an 1987 corrola gts-- thats now getting a toyota twin turbo v8.. its a shop car, so i will be using alot of stuff i have lying around the shop--its cheaper this way..:approve: or, i will need to make the stuff..its funner this way..
i had previously made mounts in the chassis,, and the motor fits fine,, and the trans and driveshaft were also in and finallized.. so out came the motor for the build, and parts i will need..
heres a pic of the intake manifold im making.. it has a rather large throttle body-90 mm-used from another project, and the rest im making as i go along.. remember that this will be a street car at about 1000 hp, so i decided to "again" run 2 sets of 8 injectors--one set for gas, one for methonal.. the second set(methonal) is only for boost..
feel free to "dis" the thing-- debate is good for progress..
also,, the original toyota rear end can not survive for almost any spirited driving,, so i have chosen to use an old domestic( to the US) rear end.. its an old chrysler-dana 60.. again,, this was lying around the shop-used.. il also attach a pic of this.. it is a spool, and has provisions for suspension and stuff, and was cut -shortened- years ago,, and also has some descent axles and brakes.. i am very confident that it will handle anything the engine can make,, especially in the relatively light corrola..
il also attach a pic of the diff..
anyway,, il keep posting any progress..-if i could find anything else around the shop that i might be able to use..:approve: :approve:
