Part number for non-hydraulic fan pulley
cebby
Not sure what this is called...
I have a hydraulic pump for the fan that I'd like to replace with the non hydraulic version. I'm running electric fans and would prefer to swap this out.
I know I can pull the unit and strip the vanes out of the pump and fill with oil, but I'd prefer to swap it. I looked on the tech pages put didn't come across a part number. I'd also like a picture of this item if anybody has one.
Thanks!!
I think you will find the part to be very expensive.
I'd try to get a used one off an LS400.
Its called Fan Bracket. Its expensive and Junk yard should have it. I runs about $140-$165. I think you can run the engine without it. Just need to get different belt. The last picture show the alternative belt path.
The fan bracket incorporates the top idler pulley mount for the serpentine belt and the mount for the air conditioning compressor so it really is needed.
