Miracle Pills?
There has been few new products on the market these days on saving gas and gas prices are climbing like a wild fire. I found this site http://extendmileage.myffi.biz/en/section_100.asp. Its very interesting in concepts but I wonder anyone have try this yet. Coating the combustion chamber is a great thing especially performance arena. I kindda want to try it. What do you guys think?
Would you call it Cialis for cars?
I think I would save my money and put it toward the cost of fuel.
Assuming it did work you would see 60 Minutes reporting on it and advertising splashed all over the place.
There have been a few efforts with tin, lead (good idea! there go the cats) and some other semi-exotic metals all in a device that looks like an in line fuel filter. Apparently they separate the atoms in the fuel so it takes up more room and goes further. They also separate your money from your wallet.
the :fuelstar: uses magnetised tin particles that rub together and release tin into your fuel - which means you casn run a leaded car on unleaded with this once off purchase of an inline fuel device. it basically replaces lead for upper cylinder lube.
costs about $AU240 - but it does work, and raises your RON another 2 points.
i just got 30 pills i will let u know if it works, it was 60 bucks, not too bad if i save gas, but in the end if u think about it your only saving some dollars, but its a save no matter how u look at it so untill someone makes a fast cheap car (haha) i will cut some corners, joy
