Piggyback ECU Link ECU
THOR Racing
Hello,
THOR Racing are able to supply, fit and tune Link XLEM ECUs to run the 1/2/3UZ-FE. (fit and tune over in the UK of course :boggled: )
We can also get versions which can run the VVTi and the E-Throttle on the 4.3 3UZ-FE versions and more modern engines.
Here is the spec of the ECU. I have one running on my Supra V8 with a 1UZ-FE. (was auto but now runs a manual R154)
http://www.thor-racing.co.uk/XLEM_G2_8cyl-LNK_XLEM_G2.asp
If you still have an auto box you can still use this ECU but you will have to run the ECU as a piggy-back onto the existing ECU, leaving it to control the gearbox. All engine fuctions are controlled by the Link ECU.
Regards
Pete
