How to improve throttle response on 3UZ-FE
toffee
Got a '05 Lexus SC430 with 3UZ-FE engine, quite happy with it except throttle response. The delay, the lag, it's driving with turbo lag without the turbo. There's a "power" setting but does little to help.
Are there anyway to get more instant, crispier response?
Yep they work well with a manual transmission , done a few now in conversions. Some running the DBW and some returned to conventional throttle. Aftermarket ECU makes a big difference especially when I can ramp up the response of the DBW. We have also done valve body mods on the stock 5 speed transmissions on the early 3uz. Made a massive difference when pushed hard yet still retained the factory smoothness when driven normally. If it was a factory vehicle I would be leaving it alone and enjoying the smooth reliable ride that it was built as.
gloverman , was it some trans kit or rather purely custom work of yours? What did it change exactly? Did the trans become switching into kickdown more happily or something else?
custom job we worked on with a transmission workshop. We wanted switchable lockup as well which we got but not in first. We up the clamp on the clutches , reduced the flar between gear changes. It worked really well with much sharper shifts with less time between shifts. We have more to do on this one yet.
