I have been searching the net and didnt really find anything solid information about how to calculate boost. I know there are many factors affecting it but here is one example:
Engine Size: 5.1L
Compression: 10.4:1
Exhaust: Stock
Heads: Stock
Supercharger: Cobra M112
Crank pulley size: 5.25"
Supercharger Pulley: 2.90"
Redline: 6,000
Intercooling: None
Fuel: Stock with Extra Injector
Can anyone work this out? I have found this an example so if we just plug in the numbers would it work?
Here's how i calculated my setup. It's pretty much the same result.
Crank Pulley Circumferance = 17 7/8”
S/C Pulley Circumferance = 8 1/16”
Ratio = 2.217 / 1
@ 5800 rpm = 12,858 S/C rpm
M62 supercharger output capacity = 1 L/ rpm = 12,858 L (LPM*.03531 = CFM) = 454 CFM of air
2.8 engine can inhale 285.6 CFM of air (cubic inches*RPM/3464)
Excess air = 454 – 285.6 = 168.4 “boosted” CFM
Boost = excess CFM / normal CFM * atmospheric pressure
168.4 / 285.6 * 14.7 = 8.7 pounds boost
2.90" Pulley Size:
Crank Pulley Circumferance = 16.50”
S/C Pulley Circumferance = 9.11”
Ratio = 1.811 / 1
@ 6000 rpm = 10,867 S/C rpm
M112 supercharger output capacity = 1.8 L/ rpm = 10,867 L (LPM*.03531 = CFM) = 383.71 CFM of air
5.1 engine can inhale 542 CFM of air (cubic inches (313)*RPM/3464)
Excess air = 383.71 – 542 = -158.4 “boosted” CFM
-158 / 542 * 14.7 = -4.29 pounds boost
2.50" Pulley Size
S/C Pulley Circumferance = 7.85”
Ratio = 2.10 / 1
@ 6000 rpm = 12,600 S/C rpm
M112 supercharger output capacity = 1.8 L/ rpm = 12,600 L (LPM*.03531 = CFM) = 445 CFM of air
Excess air = 445 – 542 = -99 “boosted” CFM
-99 / 542 * 14.7 = -2.68 pounds boost
According to the above formula even with the smallest supercharger pulley I am still in the NEGATIVE zone. Am I doing something wrong with the formula or the crank pulley is just too small or its just too large of an engine for the M112?
Engine Size: 5.1L
Compression: 10.4:1
Exhaust: Stock
Heads: Stock
Redline: 6,000
Intercooling: None
Ratio = 2.217 / 1
2.90" Pulley Size:
Ratio = 1.811 / 1
2.50" Pulley Size
Ratio = 2.10 / 1
