fuel gauge problem
ModedLS
this problem happened in my previous 1993 LS also. the fuel gauge does not read the fuel tank level correctly, but after about driving the car for a half hour it finaly makes it to correct spot. i cannot think of the reason for this. the only relation i can come up with between my 1994 and 1993 problem is that i had a system in the trunk in both cars. would the vibration cause the problem after a prolonged period?
This is a mechanical problem with the needle. One way to solve this is to get a new instructment panel and change things over. I found that out when i change my panel and play around with the needles. Mechanical movement cause that.....
