Davies Craig or Meziere Water Pumps?
cribbj
"Supra" Moderator
Staff member
Anyone tried electric water pumps? V8Supra had a bad experience with the Davies Craig unit in 2003 (documented here: http://lextreme.com/forums/showthread.php?t=138&highlight=Davies+Craig in post #3), but I've heard good things about the Mezieres.
When they're mated up with a thermostatic PWM controller, and run in conjunction with a thermostatic electric fan controller, in theory, you can keep the engine running at the ideal temperature and reduce the thermal shock (high deltaT's which routinely occur). That's in theory...... in practice however, there's now a few more new components to break. (some interesting reading about these twin PWM controllers here: http://www.dccontrol.com/intp6.htm)
I'll soon be building up a BMW motor which has had a poor reputation for overheating and blowing head gaskets. Apparently BMW's water pump is marginal for the application, as there have been several revisions over the years, but even the later motors had overheating problems. I'm considering using twin electric pumps to try to gain better performance than the single OEM mechanical driven pump provides.
Meziere claim a 55 GPM (free) flow rate with their larger pumps, so by my simplified heat transfer calculations (500*GPM*DeltaT), this puppy can transfer around 160 horsepower worth of heat continuously with only a 15 degrees temperature rise across the motor. That's not bad, so two of these ought to be able to keep the big BMW motor cool, if I can manage to fit enough radiator in the car. I don't know how much this flow will drop with added head.
By contrast, the Davies Craig unit only circulates around 32 GPM (again free flow), so it's not even in the same league as the Meziere. DC claim they successfully cooled Le Mans Ferrari racecars with two of these pumps on each motor: http://daviescraig.com.au/main/display.asp?pid=44 but I have my doubts, and would believe V8Supra's claims before DC's
Comments & other ideas welcome!
John
I know alot of speedway guys in Aus used DC elec pumps in the late 90's early 00's, but the current trend is to go back to mechanical as they were unreliable.
Some went to the extent of running 2, one on each hose.
Most have decided that the reliabilty loss isnt worth the HP gain.
I think we'll be seeing more of these things for street driven cars in the future, just like the evolution of electric fans. The OEM's were slow to adopt the electric fans, for the same reason - reliability, but they're all over them now for NVH, controllability, as well as efficiency.
I may look at putting a single EWP in as a booster for the OEM mechanically driven pump, or just go all the way with it and dispense with the mechanical one and install an electric pump for each cylinder bank.
John
John
2 water pumps may get expensive. The concensus from the road race community is to stay away from electric water pumps. The ones currently on the market just aren't able to push enough water over extended periods of time. While it may work fine for a quick pass down the 1320, running full bore at 20 minutes or more is just too much.
What do the professional BMW race teams do?
I might have one or two lying around if you'd like to try it (as long as you pick it up, I'm not a big fan of post offices). Problem is for the propper affect you'd need to disable the mechanical one, that means taking apart the front of the engine and destroying the impellor pump. I wouldn't reccomend it.
Just out of interest, checked EAP (virtual I know!!!) but its telling me that at 6K 118HP is lost to the cooling system.
accurate? not sure, but interesting!
Rivmasta, I could easily believe that figure, or one even higher. To put it in context, that figure should actually be the heat rejected to the coolant, right?
We know our engines are only about 30-35% efficient. Only about one third of the energy in the fuel goes into the crankshaft and produces work, one third goes to the cooling system, and one third to the exhaust.
V8Supra, I'd like to take you up on your offer, but the flights to Oz from the USA would be a bit more than shipping. I can appreciate your aversion to post offices; I don't do queues either.
Does anyone know what sort of volume our water pumps actually put out? I'll be contacting DC and Meziere for more information, but it would be useful to know in general what the flow curve of the OEM pump looks like.
John
