JDMfantasy
We don't have the money to buy a custom bellhousing from overseas, so were going to try and make a custom bellhousing ourselves. This bellhousing will mate an R154 gearbox to a 1UZ. I have a 1UZ bellhousing and an R154 bellhousing. What is the best way to weld the two sections together so everything lines up? How long (mm) should it be overall so everything fits as it should?
At this point, were not sure which clutch or flywheel set up were going to use, but we need to get the bellhousing done so we can put everything together and make up the motor mounts.
Also if anyone has any solid clutch/flywheel information, that would be helpful as well. I know its not a common swap, but there has to be some solid info out there. I know I might be able to figure some of this out myself, but I'm away at school and don't have the car here to look at and work off of, so anything to help me out would be more than appreciated. Thanks alot to anyone that can help.
