Parts CSL Camshafts
V8hilux
I have a set of 4 CSL camshafts to suit 1uz.
They are regrinds, and have a bit of wear on the journals but have been told they will be all good.
These were apparently run in a stockcar, and are fair agressive.
The specs below have been given to me from Brendan @ CSL cams in Palmerston north nz.
Lobe lift .412” .413”
Duration @ .050” 244 253
Duration @ .010” 289 313
Center Lines 105 108 Depending on compression ratio and power band required.
Tappets .010” .012”
Also have 32 Shim under buckets to go with them. Require Shims
These will require aftermarket valve springs.
Offers.
