zrx-fighter
after some info on why my cooling system is not working properly.
transplanted engine into a p100 pickup using an aluminum radiator and electric fans, also plumbed in a volvo 440 header tank. put new cam belt and new water pump. just some back ground info.
The issue, start and run engine on tick over or rev occasionally the temp rises the cab heater warms up and works nicely. after so long the engine gets up to 95 degress, so i turn on the fans to cool down the radiator cools down great but the engine temp just keeps rising and does not drop. as you look at the engine the hose that runs from the thermostat goes to the bottom of the radiator never seems to get that warm but the other that goes to the top of the rad gets realy hot. i do have a new thermostat in it it does work as have two brand new ones as thought the first one faulty and checked the other works.
Any one got any idea what the problem is as the car is almost finished and need this sorted before i can put on the road.
Thanks all in advance
