OK, Im not there to see the car but here goes! Remove your battery and the tray under the battery. You will see where the ground cable bolts to the body on the side of the frame. Remove the bolt and inspect for rust or corrosion on the cable "eye" that the bolt goes through. If there is corrosion take a wire brush and clean it off. Clean the bolt also.And the frame area that it bolts to. Do the same on the engine block where the ground cable terminates. If the cable has a considerable amount of green corrosion or the cable looks bad enough, replace it. This is fairly common on the SC and it shows up in ways like you described. Leaky batteries are the most common cause. You may notice a lot of white stuff under that battery tray. Smile if you see this and think how simple it was to fix, and prevent. Always flush the battery tray and battery with water when cleaning the engine.
A/C... ALWAYS charge from the LOW side only. There is a reason you could not fit the charge hose on the high fitting. If you are using a small can of freon, it can burst if connected directly to the high side. Be careful!!! The low side is on the compressor manifold. There is another by the passenger side firewall for checking the health of your Evaporator Pressure Regulator.
If you need a ground cable, let me know. I can get the OEM stuff cheaper than you can and shipping it does not cost that much!
