1uzfe into my f100 4x4
f truck time
hi all, ive brought myself a 1uzfe engine and gear box. Now the gear box seems to be from a AWD vehicle it has a transfer case but dont think it has high or low ratios, does anyone know anything about these transmission????.
The main Question is what is the simplest way to get this engine all wired up ready to rock and roll it is complete with all the harnesses uncut and will it work without the auto behind it as i dont think i can use the trany in a 4x4 application cheers.....Dano
1uzfe
Is the wiring diagram from a crown similar to the aristo as i wanted to mount this 1uzfe into my f-truck without the AWD transmission ??? also anyone interested in a AWD Transmission ? Cheers Dano
wiring loom pics from a Aristo??
well hope these pictures help out ,It would be good to know if im able to use what i have ??
1uzfe
thanks for your time much appreciated i will get down the shed after bathurst haha do the things you asked me to do and go from there..
oh the wood will be placed under the sump? thank-you
That wiring diagram i printed off from this site its a crown set up is that any help for me too look at as well
1uzfe wiring loom
Just trying to finish of my project and the only thing left is the wiring???
so any good information on how i can complete this task would be great as i have not attack the loom as yet
Thank-you Dan...
FT i would assume there is 40 wires on the weird looking plug..that said I think it's the sc diagram to go from..just the last plug looks different..(imagine you cut off that plug and put on the other 40 pin plug-then it would match the sc..)I would check the pin out numbering and how many wires agains't the sc drawing..(hope that helped..seeing i've just got mine to run,i'm trying to remember..LOL)
OPTION 1 :Hey can anyone tell me would a 2uzfe 4x4 trans man or auto bolt up to my 1uzfe engine ????
OPTION 2 :my 1uzfe came with a transmission AWD trans/caes is there another hi-lo manual trans/case i could use ??
My biggest problem is my front diff is on the passenger side ???
