no oil level sensor?
Zukijames
Lehi,utah
if i run with out one of these will it effect performance at all? make motor run in limp mode?
also what about running with out a mass air flow meter?
read that it increases power?
oil level wont effect it.
They run best with the AFM. If running correctly disconnecting the AFM will decrease performance. Often when there is issue with the engine disconnecting the AFM will overcome the issue. And you do have the wrong AFM. You need a plastic body one as you have a 20 series engine.
