Just call me "Lex"
- 12,033
- City of Halos
Finally Got the motor back. Here are the specs:
Engine & Drivetrain:
+ Custom Ross 8.5:1 forged Pistons with Chrome Moly Rings
+ Custom forged steel rods
+ Federal Mongol Mains and rods bearings
+ ARP Rods Bolts
+ ARP Main Studs and Bolts
+ ARP Head Studs
+ Cometics Multi-Layer-Steel Gaskets
+ Supra Twin Turbo Valve Springs, Retainers and Locks
+ Custom Ported heads with complete 3 angle valve job
+ EGR Delete Kit
+ 175 amps Alternator
+ 1000 Cranking Amps Battery
+ Lextreme Performance Torque Converter
+ Blue Print and Balanced
Forced Induction:
+ Custom Single Turbo header with Hot Jet Coasting
+ 40 mm Tial External Wastegate with1 bar spring setting
+ Tial 50mm Blow Off Valve
+ Garrett GT40 with Precision .68 T04E Housing
+ Custom Made 3.5" x 11" x 27" intercooler
+ Custom Inlet pipes with T-Bolts Clamps
+ 3" Down pipe to two 2.25" exhaust pipe
Fuel & Ignition
+ 8-550 Mazda Rx7 Injectors
+ 255 High Volume Walbor Fuel Pump
+ Aeromotive Adjustable Fuel Pressure Regulator
+ Custom Return Fuel Line
+ Dual 6al MSD ignition units
+ NGK Iridium Spark Plugs
+ Nology Hotwires ignition wires
+ Split Second FTC1 Fuel and Timing Control
+ ARP Rods Bolts
+ ARP Head Studs
+ EGR Delete Kit
Forced Induction:
Fuel & Ignition
