a7mgte
- 22
- Morro Bay, CA
The engine is a 1UZ in an 86 4Runner, and has 38,000 miles on it, from what I was told was a 93 SC400. (Ebay motor) It arrived perfectly clean and in perfect shape, so I don't doubt the mileage. I'm running a 91 LS ECU (I think) though, could they be different?
Currently there are no engine codes at all. (I just solved the EGR code that was bugging me forever.)
The engine is putting out about 100hp or less maybe. It loses to my friends 4Runner that has a stock 22RE on 33's. ...and it runs HOT. Despite having an aftermarket 3 core aluminum radiator and 16" 2300 CFM puller fan with a shroud.
It doesn't consume coolant or oil, although does seem to blow a little steam while at idle, it doesn't smell the least bit sweet like I would expect if it were burning coolant. It starts perfect, idles smooth, and the power band seems consistent over the RPM range, with the exception of the POWER part of that statement.
I've checked about everthing that I can think of short of doing a compression test. The TPS and AFM checked out fine as outlined HERE. When I installed the motor I did have to wire in the rear 02 sensors, but that was no big deal, and I also had to wire in the stepper motor for the EGR to get rid of the check engine light, as my ECU expected to see that motor. I've pulled the exhaust off thinking that maybe I had a clogged cats or something. I just verified the timing belt didn't jump a tooth, and put new plugs, cap and rotor on it while I had it apart. The plugs were a little dark, and smelled so rich you'd think they belong in a lawnmower though.
The motor is practically brand new, not a hose or wire on that thing is even the slightest bit brittle. I can't for the life of me figure out what must be going on. Could the primary 02 sensors get bad enough to make it behave like this and still not throw a code? ...is there a good way to test them before shelling out a couple hundred bucks for new ones?
With all of that said the truck absolutely will not provide 1st gear under power, no matter what...only when in manual low and I let off the gas does it downshift. As though first and second gear are reversed. I don't know if this could be relevant, but you never know. I have given up on trying to get it to shift properly though, and will be installing paddle shifters in the the steering wheel soon to skip the ECU's control of the tranny altogether.
