Hey all,
Im doing my homework for my project daily driver
http://forums.celicasupra.com/showthread.php?t=51601
sorry for linking to another forum, but i don’t want to start yet another build thread...
Well i decided I want to swap in a 1uzfe tied to the stock w58 down the road and im trying to get my hands on info.
don’t worry im not looking for a 'swap kit' or any thing like that. Im a certified welder, and work in a fabrication shop so building parts is no problem.
So far this is what i have collected (info wise)
-Phil Bradshaw is the man (and a very busy man seeing how i haven’t gotten an email back from him yet... but i understand)
-radiator needs to be upgraded; 3 row radiator re-core seems to be the way to go.
-Motor mounts will have to be fabricated; (found plans here: http://1uzsupra.com/)
-Re-drilled w58 flywheel is risky in some peoples eyes, but can be done easy enough, rumor has it Phil offers the service.
-bell housing adaptor plate drawings can be had here for $20 http://www.v-eight.com/tech_forum/viewtopic.php?f=40&t=753
-Exhaust manifolds will have to be custom made
-Fuel supply can be accommodated with a 255lph fuel pump
Here is what i would like info on
-If any one has a quality detail drawing of the 1uz flywheel bolt pattern (with all associated dimensions) id love to get a copy
-Any one got a link to a free wiring diagram for the 1uz, or *more ideal* a diagram or write up for the 83-85 supra swap? I know Phil has offered to sell adaptor harnesses in the past but as stated i haven’t had luck contacting him
-As with other engine swaps is there a 1uz igniter module/injector resistor pack or something that i need to get in addition to the engine/harness/ecu?
I have attempted multiple searches on this topic and have yet to find mkii specific info.
any help/links/info would be much appreciated..
thank you
thank you
 ).  There really aren't that many wires that need to be connected to make the engine turn over and run.  After that it seems to be just a matter of chasing down codes (hint: wire up a CEL for checking codes).  There are only a couple of modifications to the engine bay harness and the underdash harness to get things rolling and the dash gauges working.
