blackcat
- Messages
- 26
- Location
- Perth, Western Australia
Can anyone help? I am using a wolf 3d V4 and i am having alot of problems getting it tuned. I have taken it to several different dyno places and it still doesnt seem to run all that good. Usually runs ok for about 2 weeks and then it starts to cough and splutter.
I am also having big problems with the starting. Sound like timing problems but changing the starting ignition timing makes no difference. No-one is able to tell me what the problem is.
I am using the crank sensor and the drivers side cam sensor. I have run shielded cable all the way up to the sensor to try and reduce any interference.
Does any one kwow if i need to hook up the shielded earth at both ends of the harness or just the ecu end?
Does any one know of an aftermarket hall efect or optical sensor set up to replace the standard reluctor type?
The engine is stock with the exception of the injectors which are out of a 7MGTE.
Can anyone help me or offer any suggestions?
Would any one be able to send me a copy of working wolf map so that i can compare it to mine?
Any information would be much appreciated
Thanks in advance
Dan
Thanks in advance
Dan
