Lextreme said:
centrifugal is like turbo setup and very easy to intercooled and very effecient. However, centrifugal would not give the low end type of torque you get from Root or TS.
Hi Lex, thanks for quick response.
Yes pretty switched on to the different sorts roots/whipple/centrifugal now.
I wonder which would be the favoured consensus of opinion here? It will be in a 944 and aiming for low weight, ideally 1000kg as will be going for the ultimate 'club sport' approach ie ditching anything not required.
The car will be my fun daily commuter plus track day car. I need economy to make it realistic as a daily drive and power when on track.
I'm erring more towards centrifugal ... again! When I first investigated I chose this, then drifted towards Eaton seeing that they are easily available and cheap, and that an inlet manifold is available. Then I looked at a possible cheap Kenne Bell Twin Screw as the torque was much stronger and earlier but it isn't going to happen I think. Both give the lower down torque but in a lightweight car with 4 litre V8 am I going to miss it if I go centifugal?
Hmmmmm.....
Price wise centifugals are not cheap, even on ebay, where as Eatons are cheap cheap cheap in comparisson. Obviously Cobra and other owners are ditching them for upgrades to Whipples or centrifugals. Though to be fair they are the most in existance so logically Eatons would be the most on the second hand market place.
Zuffen has also just informed me I'd have to move the starter with an Eaton M112.
So.... for tonights homework.....
1 Eaton M112, cheap charger, new manifold needed, cheap but still a few $'s average efficiency and perfomance. Hassle moving starter.
2 Whipple Kenne Bell, Expensive! No intercooler required though fabrication of manifold and starter moving again? (I assume)
3 Centifugal (Procharger), Expensive compared to Eaton but cheaper than Twin Screw, can leave manifold, TB and plenum though would look at flow working them. Will need to fabricate mounting bracket. Efficient economy at low revs/half throttle, high efficiency and performance at higher rpm. (am I right???) Will need blow off valve.
So in a 1000kg car for track fun and street economy, which would you choose?
Discuss!
Mark
p.s. interested why your project went Vortech not Procharger? I know you listed reasons but I couldn't help thinking the Vortech wasn't the best performer? Would be interested to see if your bracket could be bastardised to fit a Procharger???
