supercharger intercooler manifold problem.
its all above the engine isn't it? or are you using a Centrifugal SC? what kind of SC are you using?
the thing is my SC will be mounted where the powersteering pump normaly sits at the side of the engine. manifold entry will be at the flywheel end of the engine, like a 70mm round pipe that flares into a 2.5cm high 18cm wide 40cm long duct that will cover the complet IC stack air entry slots.
10 characters
twin Eaton M45 ex BMW mini cooper S works superchargers.
last night I found out that an M90 doesn't fit either..... m62 Merc ones are getting hard to find for normal money, and the M45 of MINI have about twice as good a delta T graph than the old merc ones so that's why!
grtz Thomas
