adxx
- 71
- Vladivostok, Russia
btw, itb is 4a based. And by installing blacktop itbs you can get bigger holes.
Will post pics when I get engine.
Any updates on either installation? Also interested in what's been done regarding the installation of a TPS.
Sorry, man, can not tell you much on the details, my friend is a pro in engine build and electronic management tuning, so he is doing the stuff. I know that he will use MAP sennsor connected after throttle body, and crankshaft sensor.adxx,
What engine management do you plan to run? Also, what are your plans for tuning in regards to measuring engine load? Most of what's come up in my research leans toward tuning via a blend of alpha N and speed density maps. The caveat however, is that most folks tuning this way are running open bell-mouth's and no plenum. I see you've incorporated a plenum in your build so I'm curious as to how you're going to go about it.
That should work I think for probably same amount of efforts/money.I have a set of the RB26 ITB's that I want to start "mocking" up, and am pretty dead-set on running an intake plenum from either the M5 S62 or M3 S65 motor, IF I deem this project worth the time and effort to even fart around with .
Sorry for that crap in the garage - single man runs several pojects at a time (1uz ITB, Turbo-Vitz).Firstly I shat myself when that thing revved up like that !
Secondly, holy carp , there's a lot of stuff in that garage !!
