elliotaw
- 221
- Melbourne, Australia
Hi, sorry to keep posting questions on here every step of the way on my project. the reason is that I only get about an hour at a time to work on my engine which is sitting outside on a frame and usually in the dar, wet and cold so my fault finding process is barely working when I need it to.
Anyway, I have the cpu wired up and connected to the main engine wiring loom. I have the starter motor circuit exactly as per lexus manual with the circuit including the neutral/P position switch from the transmission.
My problem is that I have no output from the CPU on the Black/Orange wire, pin 4B (MREL) to operate the EFI relay.
I have tested +12v to 26B on the cpu which should be the main cpu supply.
I assume there must be some other signal I am missing at the CPU to trigger the relay.
Anyone got any ideas? I am wondering if it might be something to do with the Neutral/Park signal which should be present at 14A(NSW) ??
Elliot
Elliot
