I have a 1995 Lexus ls400 that for the life of me don't know whats going on. about 7 months ago i had my ecu fail, luckily when i went to the junk yard i found an ecu with matching numbers that was already rebuilt (by denso) swapped it in and off to the races or so i thought. about at the 2 month mark of this new ecu the car just died on me. so i thought it might have been the ecu again. asked a buddy of mine that also has an ls400 for his ecu as a loaner to see if the car will run but that didnt help. No CEL light on at all. already replaced the cam sensors. crank sensor, fuel pump, relays, fuses. you name it I've probably replaced it. and the car still doesn't want to stay running. I called up Lexus to see if possibly my car has the immo but the said my car didn't come with immo. i can keep it running on starting fluid but after that it just dies, it has good fuel pressure at 40 psi cranking, the car will fire up for a about 5 seconds before shutting off. I've done testing to make sure it isn't losing a sensor while its running and all signals are present, the ecu seems to be cutting the injectors after start up (tested with noid light). honestly love the car and would hate to get rid of it. if there is someone that might know whats going on please help out
