gtr gearbox???
if you find out what kind of diffs the 100 series uses, you'll be able to work out what parts are compatible with it in terms of lsd's and speed sensors... remember that good ol' toyota has alot of interchangeable parts in their line of cars.
btw, what car sheared the 10 inch??? and what the hell was the driver doing when that happened???
rex gearboxes all blow up. the only decent ones are the new 6 speeds in the sti's. iv never tried, but i guess they'd be quite hard to find, and expensive. supercarracer, im confused at your project, a transverse (??) lexus v8, with a subaru gearbox (?), and 4wd. sounds silly to me, but if you're that keen, and obviously have lots of cash, maybe you should check out what system the Lamborghini Diablo 4wd's use, and adapt that to the lexus. then again, it would probably make more sense to keep the lambo engine. sorry for the rambling. good luck with the project. lastly, if you HAD to mount the motor transverse, maybe a 5 or 6 speed Mitsi GTO (or '3000GT') gearbox would work.
Abit of a thread revival, but all good as it never was finished.... for one, the subie boxes aren't transverse, they're inline... and two, the RS turbo US version isn't much stronger than the sti's here... the lambo gear train is a thought, though i have absolutely no idea what they use.... again, porsche g50 transaxle is another expensive option.... as for the mitsubishi GTO/3000GT (dodge stealth), their transaxles aren't known to handle heaps of hp.... my mate has one in his shop waiting for a new gb after breaking one running 400hp at 4 wheels.
This topic will go unanswered till people actually start trying out these discussed combo's...... for now, i think best bet is a 2uz 100 series landcruiser gearbox with LSD rear end to match.... everything else would require custom adaptor/bellhousings and clutches to make them work which equals big $$$$.
There is one problem with the Subary drivetrain you guys are forgetting, the Subaru's have a short 4 cylinder boxer engine, and the front diff is in the bellhousing behind the engine, not under the engine like we need.
If you try to use a Subaru gearbox the entire engine will be far forward in the car, have a look underneat the bonnet of any Subaru or even better an Audi A8/S8 to see what I mean. I do not like that solution, as the engine hangs infront of the front wheels and the weight distribution will s**k big time.
There is one more possibillity, call it a "universal" solution. If you can get hold of a transfer box from a "GMC Syclone"/"GMC Typhoone" you have a strong foundation. These centerdiffs is a constant 4wd with 34/66 front/rear split with no reduction gears in them, so is is possible to get it underneat a normal car + they are strong. The gearbox in these GMC cars is the TH700 ( auto ) gearbox and if auto's are your thing get the whole gearbox and prep it and get an adapter made to fit it to the 1UZFE.
Summit made a 4wd rod (Quadra deuce) by using this GMC centre diff, but they used a BorgWarner T56 6 speed manual gearbox and got an adapter made up between the BW gearbox and the GMC center differential. The beauty of this conversion; the output splines from the BorgWarner gearbog fit directly into the GMC centre diff. All they had to do was to make a spacer to bolt the to units together.
If anybody of you guys know of a GMC centre diff give me a holler !
Supercarracer,
I would hands down agree with R jay.
The rex boxs are week as all hell.
You ask any rex owner and if they haven't spat out there box one of there mates have !
Well i cant stand Holdens absolutly hate the peieces of sh!t, but doesn't one of the latest holdens come out AWD V8 ?
If thats right, it would be inline and worth looking at.
Probably not that strong but may be it could be strengthened ?
It would have to handle a decent amount of torque, being an eight with four wheel traction.
Regards
Stephen
yeah thats a good thought coffee..but you also have to think of the pricing side of things unless your lucky enough to find one of the awd v8s ritten off...hence y im still looking into the gtr boxes...there available, there quite strong, they are reasonably affordable....and so is the rest of the drive train.
The 4WD system in the 'All Paw' Commodore is an adaptation of a system sold in the states in another GM car... The parts would be available there but I can't remember the name of the car...??
tobes if you remember the name of the car post it up for all of us..i wouldnt mind checking it out...cheers
Guys,
If i was to try do what you are doing ?
I would go the auto option with manual valve body and a tiptronic shifter.
Think about it, If you wanted to take off hard the auto is going to do it better and smoother = less drive train stress and less chance of bogging down due to smooth gear change.
You have to take into account that this car is going to weigh a bit !
It will most likely have the heaviest options for the diffs and gearbox due to there strength.
The extra weight and extra torque coupled with fat tyres for traction, this will amount to a lot extra stress on the drive train, i would imagin more than your grt is going to give.
There is reasons why these applications aren't produced, well not in performance situation any way.
If you doing it for the performance factor ?
These little buzz boxes deffinately quick but the rear wheel drive setup is still the quickest on the track, this is because they can't make a four wheel drive application strong enough, not fail without gaining a mass amount of weight that compramises the strenght and power gained.
If your doing it to be different well why not, but do you want something to show off that can't perform as you would expect it to ?
I hope i am not offensive as thats not my intension.
Regards
Stephen
The US car running the 'All Paw' system is the Cadillac SRX with a Northstar V8.
There are some differences;
Caddy has 50:50 torque split, Commo has 38:62 (front:rear)
Commo front drive shaft is on the left side so the chain driven transfer case has been rotated
The problems with this setup are:
Both have the front diff attached to the oil pan with a shaft through it and supported on the other side by a bearing - hard to mount a 1UZ on top of...
The Commo was limited to 270kw/475nm as the auto trans is the weak link...
The only viable system appears to be the Toyota Celsior (???) system as the motor will bolt up to the front diff assembly. Adapting anything else would be almost mission impossible......
PS - Quote from Phil Harding, HSV Director of Engineering "Its the quickest HSV we've ever had around Lang Lang"
Whilst as you put it "hard to mount a 1UZ on top of" look at what Autronic has done with his Sierra.
That man takes the attitude "if it isn't hard don't do it".
After his efforts anything is possible.
just graft the GTR "thru axle" from the RB26DETT into a custom lower sump on the 1UZFE.
that would be the easiest fix to keep the 4WD.
as for gearboxes adaptor plates...well...if you've got the ca$h to be playing around with GTRs then you can afford a grand or so for an adaptor plate!
and yes, i attest to Autronic's amazing do-ability. that's one crazy MOFO.
As much as I love manuals, I've got to agree with COFFEE
The Subie 5 speed is not particularly fragile, just not suited to drag racing.
204kW + High rpm + hard launch + no wheel spin = something breaking
Wreckers have plenty of autos, as they almost never break.
For track work, the GTR setup or Audi Quattro (see posts by Lambo) would be the best bet.
Offroad - Landcruiser parts would make the job much easier, plus you get a high/low range transfer box.
As for not being able to make AWD strong & light enough to be competitive on the track, has no-one heard of the Ferguson Formula 1 ?
They managed to win one race before they banned it. Also made a road version for a limited run of Jensen Interceptors, but you won't find one of those gearboxes.
awdmoke:
Ferguson did the Formula1 system but it was fragile and plagued with problems. A later version of it was tested in the Jensen Interceptor and the final evolution/production version of it was the Ford Sierra Cosworth 4x4/Escort Cosworth 4x4.
If any of you guys have the cash to burn and want a manual gearbox with a strong AWD sytem there is always Quaife or Xtrac
Guys,
I think we are just wasting the servers memory now.
We have all made the point !
So there is the odd system mixes of items that maybe strong enough to do the job.
But if it's strong enough there are reasons not to use it like the stupid sale figure and most likely the opportunity to get hold of one.
Unless the set up is in the right conditions even a Cosworth system will fail.
If your serious about the idea you would firstly have to get all your figures and work out exactly what you want.
How much power, how quick acceleration, how much traction is a must know.
How you work all of these out ? ? ?
But all of these will determin how strong the set needs to be and areas of concern.
Whilst no one will doubt the strength of the Sierras, the drivetrain will be under different stresses and if not aligned and matched up perfectly will surely fail.
Regards
Stephen
There's an Aussie company that makes GTR helical cut dog boxes. The can hold heaps of power and the box with the full gear (billet sandwich plate, chrome-moly selector forks) only costs As$9900. Thats a great price for a good dog box Foof for thought.
Hi there guys, my first post here. I too am looking for a very strong 4WD system for a possible 4WD street rod project, and may be able to help with some suggestions.
The GTR gearbox is incredibly strong, in Japan 1000+Hp drag cars are running in the eights on slicks with standard geaboxes, so strength is not an issue. The ratios are quite good too, 3.21, 1.90, 1.30, 1.00, 0.75 and gearboxes are fairly readily available. But the transfer case has a perculiarity in that it works in a rather unusual way. Expect to pay about $2000 for a complete gearbox and transfer case. The Last GTR (R34) used the Getrag six speed, not the old Nissan 5 speed used in all previous GTRs, and is well known to not be as strong, and prone to breakage on the drag strip as the older box.
The GTRs gearbox output shaft goes solidly to the rear diff as in any RWD car, and a wet multiplate clutch feeds power to the front wheels, on demand, activated by hydraulic pressure. There is no central diff, and it is not a full time 4WD system. It threfore needs some sort of electronic control system to make it work. Without that it will never work properly and may not do quite what you want anyway.
Gearboxes fitted to the GTST Skylines are almost identical in strength and design to the GTR gearbox, but without the transfer case. I believe GTST gearboxes usually go for about $1500, ratios are 3.214, 1.925, 1.302, 1.00, 0.752 They are a lot more common than the R154, and probably comparable in size and strength, but a lot easier to come by.
As is known here, the H151F gearbox fitted to the GXL 4WD is extremely strong, and has a transfer case with a central diff for full time 4WD, but the gearbox ratios are truly horrible. 4.08, 2.94, 1.49, 1.00, 0.881
I have no idea if the R154 Supra box can be adapted to the 4WD transfer case, or if the gearsets can be changed over directly between the two boxes, anyone here know for sure ? The R154 ratios are excellent 3.3, 1.95, 1.34, 1.00, 0.75 very similar to the GTR box. I have no idea if this is at all even feasible, but it would be a very expensive job to buy both gearboxes, and then swapping the parts across may not even be possible ??
Staying with Toyota bits, another freaky idea might be to use the new 5 speed 4WD automatic box from the GXL, fitted with a clutch. It has the good centre diff, and would certainly be strong enough, and the ratios are a lot closer than the manual gearbox. 3.520, 2.042, 1.436, 1.00, 0.716
Being an electronic auto it could be driven like a manual by using the clutch, and even by changing gear with paddles on the steering wheel as in a 5 speed sequential. For drag racing no need to use the clutch at all (maybe) except at launch.
How about the new 4WD Holden Monaro from HSV with the 300Kw LS2 engine and fitted with the Aussie Tremec five speed. It has a centre planetary differential that splits power 68% rear 32% front. The Tremec is damned strong, has good ratios, and the transfer case is undoubtedly pretty good too. I believe this same identical transfer case is being used in some Ford 4WD vehicles, but not sure exactly what.
Dellow may be able to supply a five speed Tremec with that transfer case already fitted to it, I have not checked with them yet. Chances are they are supplying HSV with theirs, so maybe it is now a standard item for them ?? Dellow no doubt can also supply bellhousings to fit the Tremec onto just about anything.
Most if not all the old 4WD transfer cases had no centre diff at all, you used locking front wheel hubs to go into 4WD, and unlocked the hubs for RWD. Not possible to drive it on bitumen in 4WD for too long without killing something in the transmission.
I have been looking at this 4WD problem for quite a while. The challenge is to find something strong enough, with good close ratios, and that has a proper centre power splitting centre differential.
It is difficult because all the really strong off road boxes have crappy ratios for a high powered V8 road car, or they don't have a proper centre diff.
Welcome along warpspeed! This what a few drag racers did way back in the 70's, my mate had a 727 torquflite with a clutch :bigeyes:
Havn't heard about this one yet but sounds interesting, before the launch of the AWD HSV's they stated there will be no manual option on the AWD vehicles (power was reduced on the Coupe4 but it still did 0-100 in 6 seconds, on gravel!). Currently the only HSV AWD vehicles released have been auto (4l65e) with an LS1 - a few of the parts (transfer case being one of them) are from U.S. GM parts bins. The tremec box holden/hsv have been using since the series II VT is a tremec T56 six speed, the 5 speed tremec was used in the BA falcons but they are now using a T56 from series II. Tough boxes but the ratios in the holden box are a bit average, double overdrive with a 0.5:1 sixth gear
