After 500km of driving, I have the following issues:
1. Error Codes
Engine 47 & 56, Trans 42 & 46
47 is something to do with sub throttle position sensor (I'm assuming trac control)
56 I read something about Hydraulic Fans?????
42 Has something to do with Speed Sensor 1 not been the primary unit
46 Solenoid 4???????
2. The transmission will only change through all gears if the ECT Power switch is on. If it's off (normal mode) will only accept 1rst gear.
3. Torque Convertor lock up only engages when I lift off the accelerator and then back on while sitting on 100kmh
4. in Neutral & Park engine will not rev past 1500rpm
Any Ideas on the above issues?
Must say still goes well, fairly economical, nice note from exhaust, very responsive.
Car is back at tailshaft workshop getting redone, their was a noticable vibration between 60 & 100kmh. Their retubing & rebalancing
cheers
