krayn
- 511
- Victoria, Australia
Hi all,
Im in the process of making a mild steel sump very similar to castlemaine rod shops. Im getting a 10mm thick piece of flat plate, mild steel, cut out in the same profile as the face of the sump that bolts up to the bottom of the motor. Once I have this I can drill the holes in the right spot to bolt the sump plate up to the motor and then make up the rest of the sump out of 3mm mild steel sheet to the exact shape and dimentions that will fit in and arround my chassis and power steer rack and pinion. Drop me an email if anyone is interested in knowing more on how I made this. [email protected]. Thanks, Kris
