deankdx
- Messages
- 489
- Location
- geelong, Victoria, Australia
hope this is in the right section,
has anyone got a pic of the cruise control cable that goes onto throttle lever, i can modify the falcon end to fit onto toyota shaft but it will have to be chopped up a bit(i'd prefer to keep it original as it was designed if possible).
the set up will easily fit and look like it is a factory install i don't have any cruise control stuff from the half cut conversion and i'm sure most would discard this stuff also, but if you have one and it looks like it can be able to be mated to ford cable pull motor(vacuum controlled electronically)(it wouldn't supprise me if i can use actual toyota under bonnet setup as the speedo arangement on the ford is electronic not cable), i'd consider buying it from you if i could adapt it easier than modifying stuff.
thanks Dean
thanks Dean
