Whats needed to run an m112 on an 1uzfe ?
Drizt
Hey guys how are you...
i just have a few simple (may seem stupid to informed people, bows head) questions.
what is required when adding an m112 supercharger to an 1uzfe ?
(i have read lextremes thread about the little things that need to be done with any forced induction, but i have a few more specific questions)
Can the stock computer (celsior) handle a supercharger?
Can the stock computer be reprogrammed ? (is it worth it, or just buy an after
market computer?)
Obviously you need a custom manifold (like the one in the group buy section
what else is required ?
i know its probably a long list, but can someone enlighten me, please.
THanks
A M112 is the physical same size as an M90 only longer.
The manifold in the group buy would suit well.
You need to set up your own drive system which may mean some idler pulleys to clear the radiator hoses.
The stock computer will accept 6-7lb of boost before running into trouble.
If you use a Crown engine and injectors expect to need to change the injectors to SC400 or larger.
You may need to build your own adaptor for the throttle body.
Cobra and Quadcamboat both have M90's running well on the group buy manifold.
Why no PM those gents as I am sure they will give what information they have.
