I would like to get the comments from anyone interested. I have a 1UZ from a 1996-1997 Celsior swapped into a 2006 Toyota 2wd truck. The stock engine was 3.0 turbo diesel rated by Toyota at 163 hp, more like 95 at the wheels. The rear end is a 3.48 LSD stock and the transmission currently is a 5 speed manual Toyota R151 with stock gearing (4.313 first gear).
I believe the 96/97 1UZ compression ratio is 10.4 Now the question. I am considering either twin turbos (Garrett T-25's) with intercooler or an intercooled supercharger, looking for comments pro and con concerning both systems.
I will keep the boost at 6-7 psi. My projected cost for either is about the same, 6k USD.
I suspect the stock transmission is good for about only 300 hp and will probably end up installing a built Ford C-4 automatic with a Gear Vendors overdrive. Any comments or suggestions welcomed.
Thanks
Thanks
