les_garten
- Messages
- 9
- Location
- S.FL
Hello,
I'm doing the Heads on my 4.7 L. for a freshen up. When the valves are ground, i am assuming they will recess into the head a little. Is there a spec I can give the machinist for installed valve height so that the shims will be 'in the Ballpark". When I did my Porsche, I speced installed valve height and Valve spring heights for my CAMs. Anything like this here?
If not, how do you start roughing in the valve lash after a top end job? Buys an assortment of shims and start out thin? If so which shims would I get to start? 1st Toy motor as you can no doubt tell.
Thanx!
Les
Thanx!
Les
