XR6 and 300ZX also had coolers mounted in front.
Top Mount is not as efficient as front mount, as you have to change the direction of air to get it into the cooler. Even with a bonnet scoop, at speed, all the re-directed air would end up and the rear of the cooler, and heat soak from the engine bay, hot air rises, would come stright back into the cooler once you stopped moving. They are good as they require less plumbing, but every tiem you want to do something to your car, you have to take the cooler off first.
