WDoherty
- Messages
- 888
- Location
- Alpine, TX
Has anyone mated a 1uz with a tremec t-56 6 speed? I e-mailed CRS and they said their adapter plate for the 1uz to TH400 would work as it would be the same bolt pattern. I'm not sure if this is true because i saw an adapter plate for the ls1 98-up t-56 for the older small block chevy. Also, the previous t-56's i n camaro's were behind LT-1's which i don't know if this pattern would be exactly the same as the older chevy small block. Anyway, i've found the t-56's for $500 in the U.S. and figure i could steal the hydralyics and and even clutch from a junked camaro. CRS also said they sold the flywheel for the 1uz and the ring gear. My car is a 92 sc400 with 94,000 miles in fantastic shape, does this sound like a good idea? Also the differential i'd use would be the 4.2... from the 5 speed sc300 as the t-56 has pretty tall ratios (but close). Please comments, ideas, etc.
