dmac
- Messages
- 12
- Location
- north carolina
what exactly is on the right side on the fuel rail as your looking at the engine? its back near the fire wall and come to find out if you don't fully tighten that screw you'll have the problem i mentioned before. its running fine now, there's a slight cut in one of the spark plug wires so i'm going to replace them and then she'll be good again. thanks for everyone's help.
pops, clean your iac valve and clean that, while its off try starting the engine if it runs a lil longer than previous, your getting too much fuel, which is a good indication that the fpr is stuck wide open. give that a try and if you need any more help if that doesn't fix it let me know.
