I am looking at picking up a 1uzfe to swap but the pickings seem to be a little slim up in BC. One I have found at a decent price so far has about 100,000 miles on it. All I know is that the yard says that it ran fine and has compression of 175-210. Is a 35psi variance enough to worry about?
I am planning on taking it a part a bit to get to the starter anyway. Guess I should probably pull the heads just to check things out. If I am going to invest the time I want to be sure that it will last and be reliable for a while. Is there anything else I should upgrade/replace while I am at it. If I pull the heads are OEM gaskets OK or is there an upgrade to look at? Timing belt, starter brushes. What else?
