boof
- 17
- Greenbank Qld Australia
I will try to keep this as unpersonal as possible as I do not wish it to turn into a mess. I will keep to the facts as much as possible and will accept any criticism that may be directed to me.
Late last year I removed the engine from my car to undertake a 1uz conversion. After reading reports on this forum and some positive feedback from past customers I asked Pete at QCA to undertake the work.
This was in January this year, after a lot of problems on a chev truck in his shop he was able to accept delivery of my vehicle in March. I paid a sum of money to cover costs of parts etc as had been agreed between myself and Peter. I was a little unsure of doing this but he appeared to be a top bloke with a lot of knowledge and great reports of honesty and service.
The conversion was to take 2-4 weeks with all the a/c and other accessories reconnected and running, a full tow in and drive away solution. After talking to Peter we decided on aftermarket management and he told me all tuning necessary would be taken care of.
I will not go on about the length of time taken so we will skip forward to the end of August when I finally took delivery of my vehicle. At the time of delivery there were some problems. The a/c did not work, the power steering was leaking, the 4wd activation was not operational, the vehicle was using 30+L/100ks regardless of driving style and was blowing fuel out of the exhaust, the vehicle was also overheating rather badly when stationary. A alloy radiator had been fitted but was too large and large enough fans could not be fitted. The vehicle also had no operational tacho.
At this point I would like to say that Pete accepted all problems and agreed to rectify them. The vehicle was returned after a fortnight when he had cleared his schedule to look at it. Upon return of the vehicle the radiator had been replaced and a good set of fans fitted, overheating solved. Power steering, tacho, 4wd and tune had also been sorted out. A/C was still not working.
The vehicle was returned again and the a/c repaired it failed several days later. This was repeated a further 3 times. This was eventually sorted out.
While driving the vehicle a couple of weeks later the a/c failed again this time causing a near vehicle fire. The vehicle lost a coil so was only running on 4 cylinders. The fault was found to be a cable run under the second battery had rubbed through and shorted. The fuse failed but melted and reactivated the short.
At this time Pete again came to look at the vehicle and supplied the parts required. The vehicle was towed at my expense to have it repaired at his shop. I picked the vehicle up a fortnight later, the a/c had not been repaired and was still faulty. The vehicle stopped 4 days later, this time I removed the dash and assessed the situation. I found a large protion of the factory loom melted. I asked Peter to employ sideshow off this forum to rewire the vehicle. I found the wiring to be a mess and a large contributor to the problems experienced. He refused stating he had a guy local to me he would prefer to do it. After a week of nothing happening I rewired the vehicle myself.
I then decided to get some local shops to assess the vehicle. The exhaust was found to be inadequate the muffler and cat deemed inadequate by 3 different shops. I have replaced this at my cost and am asking QCA to pay for 50% of the cost of the muffler, and any other rectification works required.
At this time the vehicle still has no a/c, is hunting at idle and has a flat spot off idle that have been present since the last visit to QCA. There have been other problems found but at this stage I will leave it at that.
Peter has offered to fix all problems but as I am sure you can understand after so many let downs and continual sub standard quality of work I do not wish to return the car to him.
I found him to be pleasant to deal with and this is not a personal attack against him. I may be a one off but I know I would have appreciated knowing of any problems with his work before undertaking this project.
To date QCA has been paid the sum of $9500aus. It has cost me another 3000 on top of that in towing costs and other problems associated with the conversion. I estimate it costing me another 2-3 to finish and repair the faults.
In closing I guess the old catchphrase of you get what you pay for is not always true.
Mods if any of this oversteps the boundaries please let me know.
