jordys ski boat
- 149
- frankston melbourne
i am running 15 psi with my m112 setup and there is a lot of power
Fugly-
What can the M112 Eaton Charger do for the 1uz-fe motor?...Horse power speaking? Let's figure you can make 200whp on the N/A motor if your lucky, then with the charger belt drive loss what what do you expect the charger can do maxed out....I also noticed you have the dual MSD's going...What benefit do those bring and how did you get those integrated in...I use to use the MSD's on my older small block Chevy's...Didn't think they serve much benefit on the newer Xuz-fe motors of today....Nice setup and congrats....If I had 5 grand to piss away I would definetely consider the Eaton charger...Maybe the M90 from what I have read...
Oh and the whipple chargers are wicked...We used those monsters on the 454's CID's back in the day...POWER is what we got....
Awesome looking setup! how are you planning on doing the intercooling??
That sounds like a killer combo. Make sure you keep us updated with the progress like Engine Build Up (III) with lots of pics....as I'm taking delivery of a Richwood Opcon twin screw setup in the next few days. The Opcon will start with 18lb boost and a pulley swap should see around 26lb.
I have everything I need to start building the engine, I just need to decide who I trust enough to do it.
I'm hoping for 650+ at the fly.
Looking at a water to air intercooler, the cooler core will go in the planium directly under the blower, will have to lift the blower slightly to fit it in.
