gloverman
Well-Known Member
- 3,140
- Hamilton. New Zealand
Just a couple of photos of oil filter blocks which we got to solve the location on Hiace vans but would work well on Hilux conversions as well. It can not be used with A/C. It was originally made to go onto Jet boats so the filter doesn't touch the hull. The filter comes out beside the crankshaft pulley
The machining is awesome with the unit made from billit aluminium - Bolts directly onto the block with two new bolts which are supplied and one of the original nuts. There is a port for the oil pressure sender unit at the back and takes the same filter. We remove the thread out of the old housing and screw it into this one.
I will try and get a photo of one mounted
