i came up with a new valve train a couple months back. it involves eliminating the cams and replacing them with a hydrolic actuating system. its a simple system, it only has 5 different parts; a sump, a pump, a pressure regulator, a piston, and hard lines.
the sump holds a fluid(brake fliud, hydrolic, etc.) that is pulled by a high pressure pump and pushed into hard lines that route to a pressure regulator. from the pressure regulator the fluid goes to a small piston positioned over the valve. a computer controls how much pressure is let into the piston, and for how long; in doing so, it controls the valve timing, lift, and duration. optimal HP and torque at any place in the rev range.
