brock
- Messages
- 39
- Location
- Monticello, IA
I just got a 1UZ from a '94 SC400, 175k miles, had record of the 90k mile service. I've already got it partially disassembled, down to a long block. I don't plan on pulling the heads, crank or pistons. That's just a little more than I think I need to do. Everything appears to be in good shape internally. I'm planning on a new timing belt and pulleys, dist caps and rotors, plugs and wires and I'm going to have the starter gone thru while I have it out. I also plan on replacing all vacuum hoses and coolant lines. Anything else I should do while I have it apart? At this moment I'm not planning on any forced induction. The engine will most likely end up in an Opel GT but I still need to sorce a transmission, alt, ECU, AFM, etc... Any advice would be appreciated.
