mattsa77
- 2
- narooma nsw
hi all, this is my first post, was hoping I wouldn't have to and annoy you all, I thought I had done enough research but obviously not. I have gone and bought a 98 1uz vvti with a 5 speed auto out of a Toyota celsior from Ichiban in Sydney. After I had specifically asked if the loom was complete and told scott there that it was going into a 92 hilux surf I bought it sight unseen (I live 400 klms away). well the ecu is missing the white and grey plugs (all other wiring and plugs that go to the engine and trans are there) and also the key and ignition barrel+key amplifier are missing. now the question is can I get a key+barrel+amplifier from any celsior and the key will "relearn" the ecu or do I need the original (which is in a scrap yard in japan)? what are my chances of getting grey and white plugs for the ecu? im sure no ones gonna sell me half a loom? Does anyone have a solution or have I gone and bought a $1700 coffee table? I'm a bit of a dummy when it comes to wiring so scott at venom is gonna handle the wiring. I will attempt adapting the transfer to the 5 speed auto after some research, machining and welding a plate to the bellhousing wont be a problem any help would be appreciated
cheers
matt
cheers
matt
