Damien
- Messages
- 272
- Location
- Sydney, Australia
On the weekend I finished installing a Map-ECU in my V8 Soarer. My long-term aim is to run ITB's which I have sitting on a shelf so I needed to get rid of the AFM. I installed the unit in "auto-learn" mode a few weeks ago which means it's wired up to read the output of the AFM to populate the table. I got a different firmware emailed to me which is for NA applications so I can use the whole table for better resolution (instead of having half the table wasted in the positive PSI range).
Not all of the table got filled in during auto learn but it could have if I'd put it on a dyno to go through each point so instead I interpolated the missing values erring on the high-side (dyno time is coming though). I replaced the AFM with a length of 90mm PVC pipe (as it's only temporary) and fitted the temp sensor which came with the Map-ECU and changed the wiring so it outputs to the stock ECU.
It fired up fine and I went for a cruise around my place and the only anomaly I found is that it hesitates when quickly opening the throttle from cruise. It has a TPS enrichment function but even at 30% enrichment it's still hesitating. I email Peter at Performance Motor Research (Map-ECU guys who have been exceedingly helpful) and he suggested I watch the load zones as it goes from whatever the vacuum is to 0 PSI as I may need to make it a bit richer in those areas. Apart from that it cruises and accelerates well which I understand can sometimes be tricky on MAP-bases systems.
Instead of dicking about on the road I'll be taking it to a workshop nearby who has a dyno and the operator's pretty cluey.
Anyway, just wanted to let you all know what's in the works and I'll let you know how it goes once I've taken it to the dyno to get it sorted, but if anyone else has ideas on the hesitation let me know.
