Jake Breyck
- Messages
- 1,019
- Location
- Florida
alright so i set my motor in my car this weekend and i like its location, although before i finish fabricating the engine mounts, i would like peoples comments on the location of the motor.
my reasons for this location...
weight more to the center of the car.
room up front for two turbos and possable Vmount IC/rad
dont have to make an oil pan, this works with the stock rear sump.
doent seem to make any of my other fabrication any harder, everything i have to do still i had to do no matter where the motor is placed.
also points to note, the seating position will be further back as will the peddals. i could see this motor position as a problem if the seat and pedals where going to be in stock locations.
the woodel dowel is acting as a spacer giving about a half inch clearance between the pan and the rack.
Here you can see just how far back it really is.
From inside the car.
Straight on shot.
this car is being built for my posonal fun, ill take it roadcorse track days, not really going for a dragster. but dont hold back any inpoint will help befor i finish the mounts and wont want to change it.
if you want to see the rest of the build up till this point here it is.
http://lextreme.com//forums/showthread.php?t=4724
Straight on shot.
