First of all, $ is a major factor for me, I know I should by the best but I can't.
My 1uz has a centrifugal supercharger on it, running blow through MAF and stock ECU. It's runs okay on petrol, but definitely struggles at high revs (avoid.)
The tricky bit is I have LPG vapour injection also. This system has it's own ECU and controls fuel, I think it works like a piggy pack and listens to the injector pulse signals meant for the petrol injectors, then goes from there to work out it's needs. 90% sure it doesn't control timing (big factor with lpg I think.) It's struggling big time lately, I'm not sure if it's boost related or the MAF or both (probably)
My guess would be some sort of standalone that can have two independent tune maps, switchable via a toggle or relay. That way I can have a complete tune for petrol and seperate for gas. Though I want to run lpg 99% of the time. But, how would you wire up 2 sets of 8 injectors seperately from the one ECU?
The cheaper option would be one of these halfway MAP converter gadgets, then tell the original ECU it needs more fuel. I assume then the LPG ECU will do the same for the LPG injectors.
I noticed the MAP-ECU 2 has timing control and 2 seperate switchable tune maps too. But it would be installed as well as the stock ecu and lpg ecu, that's a lot of wires! Though it does have a self calibrate tune feature and what not. But the cost is not much less than the bottom dwelling standalones, I think the Adaptronic is under $1k.
Any thoughts on what people would do were it them? Ditch both ECU's? convert to MAP and keep originals?
I think either way I have to lose this MAF, it's causing big dramas.
