4000GT
- 2,043
- Christchurch, New Zealand
So I went from a twin plate QM 7.25 inch setup using a hydraulic release bearing to a full sized cromoly flywheel, with a 10" Nissan 1600kg cover and 9.5" 6 puck ceramic sprung centre disc.
The multiplate is not nice at all for the street, short life span and hard to engage smoothly, hard on gearboxes etc... great for race cars which are coming apart every season, but not a great street solution! Also not the easiest to setup the spacing etc as you lose the play in the slave and fork approach with the floating hydraulic bearing system I used.
The big single setup with a 17mm slave gives heavier pedal feel, but engages well, holds the 500WHP Im currently making, doesnt chatter or rip your face off when at the lights and trying to make it to the next one. It was not a cheap solution, but to deliver the capability to power holding, being much more streetable, its worth the investment in my opinion. It was one of the clutches Gloverman is now offering.
