Just took a couple of pics of the waste gate actuators, as you can see i had to modify one of them by moving the mounting bracket from the front of the compressor housing to the rear of it thus also had to shorten the actuator lever. Would this have any effect?
Hmm kinda suggesting you do some reading yourself as the reasons are laid out in any decent turbo text. Yes this is a great place to learn but you are asking questions on someone else's thread...maybe i'm just old skool but i learnt most of what i know by teaching myself or maybe i'm just a cranky old bastard
However, free revving will easily see both surge and reversion of the throttle plate....both of which will pulse air out of the comp housing. I can do this easily any any turbo can i have owned or worked on. Third way this could happen is if the turbo wastegate control gets out of sync ie. one turbo is boosting and the other is not...the air takes the easiest path one of which will be out of the non boosting turbo
technical enough???
I start by removing the air intake filters, i then get someone to hold thier hands close to the turbo intakes while increasing the engine rpm to around 3000, you can feel the turbo's suck you hands in then they blow back then suck in then so on.
Certainly sounds like mild compressor surge to me.
At part throttle the compressors can and will make pressure between the compressor outlet and the throttle plate. If the BOV is not bleeding this pressure then the turbo(s) can surge. Compressor surge occurs when there is insuficient air flow for a given pressure. At very low air flows (such as throttle restricted slow reving and cruising) the wastegates are closed (so they are not involved in this condition) and the compressors are moving air and creating pressure at the throttle plate. Look at a compressor map and at very low air flows it takes very little boost to cross the surge line.
Remember at cruise at say 45mph you are only needing say 10rwhp. This is a small amount of air mass. With 2 turbos this mass is cut in half. But these turbos are still moving air. As the pressure goes above the stable range for these compressors at THIS low airflow surge is encountered. Under surge the air will momentarily reverse. NOT the compressor direction just the air flow direction. As soon as this happens there is enough room for the compressor to move air again. With 2 turbos this easily becomes an occillating condition as describe in the original post here.
A true compressor bypass valve will correct this. A weaker spring in the BOV may also fix the problem. You simply need to bleed the pressure under these conditions.
2 things spring to mind...you are hitting the surge line ie the turbo is trying to make too much boost too low in the flow range which suggests to me you need the bigger a/r turbines...OR...your boost control is mismatched so your turbos are alternating making and dropping boost.
Well no, its not technical enough... it doesnt seem like anyone is addressing his issue. Which is what I have in mind when helping troubleshoot his problem.
LOL Thanx JBrady, just what i said in the very 1st response
External gates are great to solve this prob as most have a vac port on top to open the wastegate under cruise (vac). Personally, i have never used this as my turbos have always had a reasonably large turbine which makes this condition rarer.
To see compressor surge free revving to 3,000rpm without load (assuming its not on a dyno?), is fairly extreme. Its got nothing to do with the WG at all...
Not free reving. Steady state cruising. Read my post again as I describe how this happens.
Right so someone was holding their hand over your turbo while you were cruising at 3,000rpm? Were they sitting in the engine bay or something?
OK should of said this before, thought i had....
But it also has this problem when i drive the car.
I can drive along at about 3000 rpm in any gear and its fine but if i decrease rpm slightly i get the surge. Under accelaration its ok and when changing gears the bov vents and i may get a little amount of surge.
It seems to be mainly at the point where the bov is not able to vent that it does it.
