A quick question for those in the know.
Building up and engine for my car, and would like to know if this seems realistic.
1uzfe with 8 throttle body manifold. Probably the one from tmiller in NZ as seen on this forum. EMS of Austronic or similar ecu, stock bottom end, 91 thou copper gaskets as adverised on this forum, modified cams to suit, and maybe a little port work on the head plus 150 shot of nos. Planning to use direct port wet system.
Any comments, or will i need to go forged pistons and a full bottom end rebuild. Only after about 500 - 550 HP at the flywheel.
Also, turbos and blowers will not fit under my bonnet.
ADAM.
ADAM.
