Been having some issues for a while now with my 1UZ (UZZ31) hilux. It has stopped idling properly and is a pain to start. The first start of the day, it will barely idle and usually stalls. Some days it will start and idle fine at 1200RPM and next day, nothing. I can't drive it, as everytime I brake or slow down, the idle will drop severely and it stalls..
Have done the following to try and find the problem:
Cleaned/Rebuilt IACV
Cleaned throttle body
New fuel pumps (lift pump and Bosch 044)
Water temp sensor
Checked for vacuum leaks
Checked ECU for leaking caps
Was listening to the motor and there is a hissing sound coming from the fuel pressure regulator. When the vacuum hose is removed from the FPR, the idle increases a lot.There is no fuel getting into the hose from the FPR.
Where can I purchase a new FPR from? Toyota will have to order from Japan and that will take weeks. Is there an aftermarket one that will bolt in?
Water temp sensor
