toy4whatever
- 40
- Buckeye,AZ
This will be a slow build but not to slow. I should finish this year sometime.
So after patiently waiting for almost 2 years I bought a 1993 LS400 for $550. The couple I got it from said the fuel pump went out. I got it home and removed the fuel pump only to find it was stuck. I turned it with a pair of pliers and freed it up, put some jumper wires on it to see if it worked and it did. I put it back in the car and damn if it didn't fire right up.
I bought the pickup over 3 years ago from the original owner. It only had 81K on it and after only 2 months the motor blew. I replaced it with a rebuild and it lasted a year. I decided then I was going with a different motor. I had originally planned a 302 swap and even had a motor that I was building. Got a lot of really good parts for cheap but it was going to be to much motor by the time I got finished. So back to square one.
During all this time I had bought a solid axle and did the swap. The truck sets on 5" springs up front with 63" chevy springs out back. The front is a Trail-Gear kit while the back is some of my own creation.
THE PLAN: I will be doing most of the fab work myself. I am using a V6 transmission the will have 2 4cyl transfer cases attached to it. I will be making my own bell housing from the 1UZ and Toyota V6 bells. I will be using a Toyota V6 flywheel and clutch set-up. I will be keeping all the 1UZ accessories including A/C.
Here are some pics in order from when I got the truck til now.
