IndianaJones
- 3
- South Africa
Hi
I'm about to fit a Toyota 3UZ V8 motor & A650E 5-speed auto trans into an older model pickup.
The VSS (vehice speed sensor) on the auto box is apparently a 2-wire inductive sensor, and plumbs into the main ECU harness, and as far as I'm aware of, can not be eliminated, as it is needed for the ECU and TCU's calculations.
It is a 2wd pickup, and there is no other location for a mechanical speedo pickup, for instance a transfer case.
I would like to retain the original gauge cluster, but how does one get the mechanical/cable-operated speedometer working, and calibrated?
Are there other gearbox tailhousings available, with locations for both types of speedo drives?
Regards
Regards
